avatar_Appalachiosaurus
Recommended toys?
Started by Appalachiosaurus, September 14, 2014, 06:54:22 AM
Appalachiosaurus
Hello, I am new here and I am looking for a dinosaur toy! I am looking for realism, a reasonable price, and a good display value(I don't think I will actually play with it). Any recommendations from you guys?  ^-^
what size range do you prefer?
Manatee
I personally recommend the Papo and Wild Safari lines; they are the most detailed and Wild Safari is hard to beat in terms of accuracy.
Define realism. Life like, or scientifically accurate? Preferably both no doubt, but you don't often find both. Papo's figures are often considered realistic in the former sense of the word, while accuracy is more along the lines of recent Safari and Collecta figures, and various Japanese lines that are not as easy to come by.
DinoLord
Also consider the new Terra by Battat line. The models are pretty well-detailed, very accurate, and are overall aesthetically pleasing. You can pick them up for $8 at your local Target.
Appalachiosaurus
Quote from: stargatedalek on September 14, 2014, 11:08:27 AM
I would like to keep it small, no CollectA deluxe. I would prefer around the Papo Dilophosaurus in size.
Quote from: Roselaar on September 14, 2014, 01:40:04 PM
Scientifically accurate, although if there is both I will gladly take it!
Quote from: DinoLord on September 14, 2014, 02:17:20 PM
A specific one you would recommend?
DinoLord
The Cryolophosaurus is my favorite of the Terra line.
If you want small stuff there's the Kaiyodo Dinotales line. Each figure is 2-3 inches.
The Kaiyodos come indeed highly recommended, though they're not the easiest to find. Favorite's Softmodels are also a good choice, though they suffer from a similar issue.
Avoid: Schleich.
DinoLord
Quote from: Roselaar on September 14, 2014, 03:59:11 PMAvoid: Schleich.
^Very good advice right here. Not only are their models overpriced and painful to look at, but they have some rather unscrupulous marketing practices that hurt companies that actually do produce decent figures.
Kaiyodo and Colorata are good candidates for small display figures, but you will have to keep shipping in mind
favorite co soft models are a bit on the large size compared to the Papo dilo, about that size but just a bit larger
SBell
Avoid: Schleich.
Agreed. Go with Japanese whenever you can!
Schleich is terrible. Which is sad, because they should be the standard.
Most likely, you will want to pick and choose--Mojo makes great mammals; CollectA has really come into its own in the last few years; most of Safari is amazing (and their toobs offer some excellent small figures).
the Schleich modern animals normally aren't half bad, which only serves to make their dinosaurs that much more enraging
Safari vary greatly in size
tanystropheus
#12
Some of the recent Papo figures are both realistic and accurate (e.g. Dimetrodon, Dilophosaurus, Carnotaurus, Styracosaurus, Pachyrhinosaurus, baby Trike, baby T-rex...and Archaeopteryx to a lesser degree)
The Papo Running T-rex and Brachiosaurus are worth getting but not altogether accurate.
Arul
#13
In my opinion,cheap+detail+displayable = tamiya dinosaur model kit...but if you seeking for some real pleasure,sideshow...
the baby Papo tyrannosaurus is not very accurate either, a young tyrannosaurus should be more lithe than the adults, not bulkier
but thats getting off topic
with lines like Wild Safari and Carnegie they vary so much in size that theres bound to be some in the size range you're looking for
tyrantqueen
Safari, CollectA, Battat, and Favorite are all good choices.
Papo has great sculpting detail, but nearly every one (if not all) of their sculpts have anatomical flaws.
